Weird problem with a G5
texwash
Today I was going through the wash and noticed an unusual problem. The UC and high pressure functions work great, but not the lp soap or triplefoam.
During the soap pass, nothing but air comes out of the lp nozzles, however a slight stream of water comes out of all the high pressure nozzles. The same issue happens during the triple foam pass, nothing but water out of high pressure.
I contacted a tech from pdq who told me it's the change over valve. Do you guys agree with his assessment? Also, my distributor does not have any valves in stock, but rebuilt kits. Is there a source for aftermarket ones?
You might also want to check the distribution block up in the bridge, i've had that clog up before and it caused the problem you're describing. On the aftermarket valves...couldnt help you there
