weird vac problem
Jimmy Buffett
This may be a Jim Coleman issue but it may not. I have 3 vacs on 2 islands fairly close together. All 3 of these vacs are, at times, counting 2 pulses per quarter. I have never seen the other 2 do this but I cannot swear that they do not. I switched the Sensorton and that had no effect. I did have a Money Manager problem a couple of months ago when my shampoo vac was dripping on the coin acceptor. At that time I replaced the Sensorton and unhooked that vac from the Money Manager and all seemed to be well. I do not know if my other problem started then or not. We hooked it back up last week and the problem remained. All I can think of that they have in common is Money Manager and wiring. Anybody have any ideas?
You could unhook your Money Manager from all of them temporarily to see if the problem stops. That would at least tell you if it's related.
Jimmy Buffett
I thought of that but it was not clear which wires were the mm. When I took it apart the wiring did not look the same as my shampoo vac.
