- Joined
- Aug 30, 2007
- Messages
- 4,292
- Reaction score
- 1,180
- Points
- 113
- Location
- SW Indiana melon fields.
Recently I developed a leak at one of my remaining Cat 5CP-2120 pumps. Water was coming out of the hole in the Suttner unloader. When it finally got bad enough I decided to swap it out. All was well for about a month and then the new one started leaking. I also felt a slight pulsation in the pump so I yanked it apart and found a pitted valve disc and one LP seal with a small nick. When I realized I didn't have a seal kit I decided to just go ahead and install the Arimitsu that I eventually planned to install anyway. I put the pump on with another new unloader and all was well at the wash again. That was two weeks ago, today I notice the second new unloader is leaking just as the two before it. Any idea as to why all of these unloaders would leak? Pics of both pump set-ups are below.
Cat
Arimitsu
The shot of the Arimitsu is a little deceiving. That tee with the guage and check valve is screwed into a port in the head. The angle of my shot makes it look like it is screwed into the unloader.
Cat
Arimitsu
