Which chemical injector do you guys recommend?
Lexington, Ky.
koliver
PDQ Sales Engineer
DePere, WI
The main difference you are going to find with these injectors would be the hose barb. On the HFI injector, this hose barb is molded into the injector and not serviceable. On the GP injector you can get a rebuild kit should the check ball/o-ring go bad. You won't go wrong using either one.
