Wizard Triple Foam
Greetings Wizard owners. Maybe you can help with an issue on my 1.0?
My triple foam is not coming on. On the Red Lion, if you use the test feature it will not turn on the motors. However you can push the triple foam contactor and the motors will work. Any ideas?
Check the low water level floats in the triple foam tanks. One of the tanks is low or you have a low level float that is not working correct. Look on the Red Lion and it will tell you what float is indicating a low level situration and this is why your pumps will not turn on.
Rob
