MY IBA entry door intermittently won't close when it should (wash starts and temp is cold).
The chicklet relay corresponding to 'entry door close' is lit (LED) and I have swapped out the chicklet just to be sure that isn't the problem.
When the door fails to close, it also will not close when I press 'close' on the 3 button station. I cycle the power (on the fuse panel braker), then the door will close when I press 'close' on the 3 button station.
Any clue? bad 3 button station or a switch inside the operator itself?
Operator is a 1 year old liftmaster jack shaft style.
TIA~
TIA~
