WSll "exact change only"
coin jam? I'll probably start by emptying the whole hopper completely. Unplugging it, taking it out and giving it a good clean out/blowout. Refill part of the way and test it.
tdlconceptsllc
NC
Power Cycle it Coach "After " you fill the hopper seen this alot with mine when it ran out of change in hopper.
I have plenty of Gold Dollar coins in the hopper. What's the deal?
You can no longer just call them up.?
Nope, you have to make an appointment unless you are a distributor. They are discontinuing manufacturing and support for that machine will eventually end.
Amazingly though, it seems many operators are figuring out their own problems without factory support. I think it's a testament to a good initial design. Used WSIIs will likely be common for at least another 10-20 years. Mine were manufactured in 2001.
Seems to me someone technically inclined could build their own cashier with a PLC and use crytopay as an CC interface pretty simply.
Fatboy769
Living the American Dream
Irmo, SC
[QUOTE="Greg Pack, post: 201684, member: 101"
[/QUOTE]
We both know someone with that capability in your neck of the woods.
