WW 1.0 Presoak issue
Hello all,
The presoak on my WW 1.0 doesnt start coming out until it is over the hood. Could there a solenoid problem somewhere? I havnt seen any leaks anywhere either. Any suggestions wold be greatly appreciated.
John
when i troubleshoot a problem like this i start from one end and work out from there. first i check foot valve in soap. then metering tip. then injector, then chemical line ( tubing ), etc. could be a small rub through leak in the tubing where you can't see.
i would run the presoak manually and look at the tubing from soap barrel to nozzles.
