mrfixit
Years ago I had the idea to move from our float tank/flojet/ pressure injection into opposite feed inlet on a hypro pump. For our hp soap and wax... Hopeing to eliminate some equipment & problems by direct injecting with the zero pressure..
One reason is we experience a high pressure drop, till we add more softeners, when the hi-impact auto runs. Line pressure drops to about 35 from 85! So the flojet head pressure at 85 starts pumping over city pressure increasing the chemical usage when auto is running all day.
So I finally replumbed one bay up yesterday to try it.. Its working.. But the bypass hose off the regulator is collapsing from the vaccum and causing a drop in psi when cycling the trigger. It runs at 1300psi and trigger cycles cause it to drop to 800 for a second. Like its starving, with a little rattle.
For one that particular pump has a 150psi bypass hose that is flimsy compared to the 250 hoses on the others, this could be the whole problem... I also had a problem with regulator but rebuilt and it was working fine with the old set-up..
The bypass was on the city water inlet side T'd in. I moved it to the opposite side when I replumbed. Not sure if I just need to re-t to the city side or if it just doesn't work this way with zero reg.
Another thing I am seeing that chemical change over its taking about 45 seconds from soap to rinse.. Not sure if its normal or if I just need to rebuild the used kips valve now with the added vaccum on it instead of pressure.
Any knowledge would be appreciated..
With the flojets inherent intermittent problems I'm hoping this will be more reliable with less parts to fail.??
