PDQ Error - Trolley Motor over current fault
Andyscarwash
Hey,
Just wondering if anyone has had this error occur?
Error: Trolley Motor over current fault
Cheers
pcb
Leprechaun Car Wash
Dublin, Ga
Something is causing the amps to go to high for the trolley. It could be the motor or gearbox or something is keeping the trolley from moving. Trolley could be hitting something or could be a roller flat spotted.
Monte
I believe I got that 6 months ago on my 360+....I decided to change motor/gearbox. That cleared everything up...but never can be 100% what specifically was the problem. I think it was tired gearbox.
dallas
9 times out of 10 its the motor/gearbox. Could also be the cable. What kind of PDQ is it? Can't rule out the VFD as well.
AquaAce
Give their tech support a call if you haven’t already. I’ve been pleasantly surprised a few times. I had a similar issue with my Tandem Surfline and after explaining the issue to tech support they told me to look at a certain connection on the vfd. I disconnected, re-connected and it’s been no troubles for over a year now.
Zal
Illinois
Trolly prox or the flag is bent out of shape from the chemical corrosion, Typical problem when I get this error. It doesn't stop at the extreme end-one side or the other and trips overcurrent fault - if so, easy fix.
