Post pics of your wash here...
Status
Not open for further replies.
JacksonV
Administrator
Staff member
TN
Post pictures of how you did your wash.
I frequent several car forums where people post sometimes lengthy threads on their vehicles from the time they buy them and basically document everything they do. I'm thinking about doing the same here with a run-down wash I just got hold of.
H20man
Southeast Nebraska
After pictures only of a 25 year old wash that sat for last 6 years. Bay walls were patched with epoxy resin then industrial coated with 2 part epoxy floor coat. 6 month and holding up fairly well.
Eric H
Leominster, MA
H2Oman, Is there a reason for the S bays height bar being at 8'6"? It looks like the exit may be lower than the entrance but I can't see for sure. I am thinking of lowering my door height from 12' to 10' on all but 1 bay to keep the commercial trucks from making mess in every bay.
BTW both washes looks great! I'll be adding some pictures of my own soon
H20man
Southeast Nebraska
There are roll up doors on exit side and the are at 9'. So yes the entrance is higher. hence the bars set at 8'6"
That looks like it was built by Superwash. If so with the roof slope to the rear and the roll up door clearance is why such low clearance.
Lexington, Ky.
These are the before and after of our rehabbed wash. It was down for 7 years before we purchased it. Many thanks to the contributors to this forum!
View attachment 338 View attachment 339
One of my washes has a roof similar to this, but the metal is bent and beat up in several areas. Any idea where I can get a similar metal to replace it with? I've been painting it, but the areas that have been hit are adding up.
bert79
West Michigan
Hi slash, our metal looked the same way before the rehab (beat up in many places.) We decided to replace it all. We went to lowes, but home depot does the same thing. $624 replaced the metal on the whole building and we did the tear out and install ourselves. Both home depot and lowes will custom bend the metal to your specific needs too just fyi.
Lexington, Ky.
I was actually in Lowe's yesterday looking at the metal. I found some long sheets that were similar, but not the same, so I would have to replace it all. Any chance you could give me the item # of what you bought? Also, were you able to find the channels that sit on top and bottom at Lowe's? I didn't see anything there that I thought would work. Thanks!
Menards has a better selection of metal roofing if you are looking at a box store but a local metal roofing supply might be your best bet. They can supply it with the right roll profile, gauge, color and already cut to length.
bert79
West Michigan
Hi Slash, I’ll PM the quote so you can get the specifics.
Roz
Purchased a place built in 1990 and run into the ground until Summer 2017 when I purchased it.
Roz
Had a museum piece for the IBA, an old, tired, Mark 7 Roto Clean that just moved water in a haphazard way. Bay was dark and dank. Bays had two working functions, HP soap and Foamy Brush. Equipment and pipes broke down (or simply broke) on a daily basis. Coins jammed in the meter boxes all the time, what little revenue there was....
Roz
Many months later....we totally renovated the place...New equipment, new pipes, new electrical, and new (heated) floors. Most important new customers!
Lexington, Ky.
Would love information on what you did for the heated floors. Mine suck and seems like I need to do something similar to what you did. Did you replace an existing system, or put new? If new, how did you get the loops out to the concrete from the ER?
Roz
We replaced all the lines from the ER and the two manifolds on the boiler. The new manifolds came with individual controls for each line (one per bay) so we can regulate the flow/temp based on distance to the ER. The 30 year old 500K BTU boiler still runs and can heat an apartment house according to the plumber. Only 80% efficient but saving $10K for a new boiler. Getting the lines through the wall was easy for the plumber.
Process took 3-4 full days.
Day1: Demo floors in 5 bays and start boxes for new floors
Day2: Rebar (we upgraded to a stronger than average rebar so trucks are not an issue) and slightly stronger rated concrete
Day3: plumber lays all the lines, 10"-12" apart in each bay tied to the rebar. All the lines feeding each bay go thru the new apron area that is also heated. Plumber added a pressure gauge to the lines and pressured the lines to make certain the concrete guys did not mess them up or puncture them (which seems to happen if concrete guys do not pay attention to details).
Day 3a: We took advantage of the open floors to add PVC pipes to capture the weep water from brush and wand. In hindsight I might have added a spare unused PVC for the future and a line in the exit area apron as the material is the cheapest part of the work.
Day4: The concrete pour and grading the bay floor slope toward the pits - big difference as you can see the water run to the pit.
Day5: Plumber mixes the glycol/water mix and adds to the system. He used the anti-corrosion glycol version.
First winter all the bays became ice skating rinks that had to be closed at times for safety. This winter we never had any ice in the bays or leading up to them. Customers have noticed all the changes and improvements reflected in feedback, comments to me directly, and business. Get a good commercial plumber to do the work, a residential plumber may not be as experienced with this work. Not rocket science but reassuring to have a plumber who knew what to do and help the concrete guys not take shortcuts.
Lexington, Ky.
Man that seems like you had a good crew. I'm going to need to do the same. Afraid to ask what that costs. My current setup does not cover any of the front/back aprons and is only a circle in each bay, so around the edges and near the grates it does not work. Also does not work in a large section in 2 bays.
Status
