2010 vector rapid carwash
umherrk
Looking for a manual for an oldschool belanger vector rapid carwash. Found the POS4000 console and the interface manual but thats about it. Outputs controller is the same as the one in the picture.
1887 - Belanger - Vector Rapid Wash - Vector - Carwash Consignment
having an issue with the coin acceptor, I’ve set the tokens it accepts to read 6 pulses per token. This requires 5 tokens for the car wash to initiate the wash, (30 pulses) however it initiates the worst wash option (without the undercarriage wash and the dryer). When I change the pulse /token to 32 pulses (no indicator lights lit on #of pulse/s) then the wash works using the undercarriage and dryer but now only 1 token accepted initiates the wash ( where I can want to use 5).
What kind of auto entry system do you have? Like in ACW. Most ACW's require a coin acceptor that is specifically programmed for there equipment. Most of the time you can't install a coin acceptor that is made for a coin box and install it into a ACW, the pulse rate is different.
It’s a Belanger saber, pos4000 console , and interface.
