360 onboard water replacement
jaykay
upstate NY
Two of my 360+ onboard water heaters need replacing. They have cracked a couple of times and I have had them rewelded, but now the elements are tired and can't keep up. Has anyone come up with a different replacement solution. These heaters are pricey, I was quoted a price of over $6000.00 each.
Keno
What kind of heaters are stock? You may get better responses with more details, specs and pictures of the heater you're trying to replace. Would a tankless heater work and fit in there?
koliver
PDQ Sales Engineer
DePere, WI
You can look to install a external/wall mounted on demand heater or a small tank option. These can be purchased in electric or gas.
TWCHEV
Iam also looking for a new hot water tank, I've had mine welded on 3 times. Only lasted 4yrs. Was thinking about a home hot water tank maybe, just wire and plumbing. Anyone else do that?
GPAW
Just curious, but do you need the heaters? We are in cold climate and run soft water with a boosted alkaline presoak and cars come out very clean on our 360+’sWe do have our boiler run hot water for our weep though.
TWCHEV
Iam in the pacific northwest, according to my service company they say we should use hot water. Using Venom and Marvel for the presoak
