I replaced the high and low pressure seals in all my pumps about four months ago. Now one of them are leaking under where the head bolts on to the pump. Can seals go bad that quick?
Yes, but it may not be the seals in the head. If it's dripping all the time it's probably a low-pressure seal. If it only leaks when the pump is running, it might be the plunger seal.
