Since my first thread turned into a pump war lol, I wanted to start another thread with a couple of questions...
I have a question on RO membranes. I want to change the 2 membranes before I install it, but not sure if I should get the cold or hot water versions. I will be using hot water, but I know that some people use the cold water version regardless. Pros/cons to each? Also, for a JC pump stand, anyone know what size membranes I need to buy?
Second, attached is a picture of the current pump. Since I have to replace everything for the 4 missing pumps, should I keep it exactly the same setup, or is there a better way to set it up (cleaner/simpler)? Also, any parts that I should get different versions of since I am buying new? Like the solenoid (I'd likely run at 1300 psi) para plate, the pre-soak regulator, etc? I also see a pop off valve. Is that needed?
