Air dryers
I have them installed at all 4 of my Air Lift doors, but no where else. Wasn't sure their function or advantage. Thanks.
Did you fix your water in the dryer problem?
Not yet. After 3 rounds of snow we've been busy, so I haven't had a chance to shut the air off and test everything like I planned. With my IBA doors being air operated, I can't shut the air off now. I did receive today the auto drain air filter I purchased, so I'll test and install on the first rainy day.
So far I was able to test my two IBA's and 2 out of 5 SS bays and non water came out of the air line when running high pressure. I did put an auto drain water separator for now just to see how much water it catches, but have not turned the air dryer back on yet.
I wouldn't want to have anything in line with the auto drain. You don't want to separate the water, you want it to go down the drain.
