We have a mixture of Airlift Magna Glides, and Power Glides (PG) in our IBA’s. They are all horizontal ceiling mounted units. This morning I got a call that an entrance door wouldn’t open all the way and stopped by to check it out. The Power Glide unit that was ~2yrs old had broken away from the ceiling bracket that holds it in place. After looking closer, there are 2 - 5/16” D x 1/2” L Stainless Steel bolts that mount the bracket to the aluminum block on the end of the Power Glide unit. They had both stripped out of the aluminum which caused the unit to drop.
I checked the installation packet to make sure we had installed it correctly, and we had. Airlift says to mount the power glide unit under the horizontal section of the ceiling bracket. The entire weight of the unit, rides on those 2 small bolts holding it in place. Since they were stripped out, and I’m not a fan of using helicoils to repair equipment, I flipped the bracket over and mounted the Power Glide to the top of the horizontal piece. Should those bolts ever tear out again, the bracket will at least hold the unit up. Since this is a first for one of those Power Glides, I’m going to change the bracket mounting position on the rest of them as a precaution.
The entrance door wouldn’t open, so no damage was done to a vehicle. However, if it had been an exit door, the unit could've dropped down on the car.
