Eric H
I’m replacing a seized rotary switch on a SS faceplate. I thought some people would like to see the insides.
1st photo shows where the switch corroded causing the switch not to move. The corrosion is at the bottom of the switch at the spot where the stem protrudes from the body. The water follows the stem (where the knob is attached) into the interior of the switch and pools.
the next picture shows the 2 stacks on this 10 position switch.
Numbers 10-19 show the smaller finger that breaks the contact before touching the next contact. This is the “Break before Make” portion of the switch. These contacts should be used to control solenoids or relays.
numbers 20-29 show a larger finger that touches the next contact before moving completely off of the previous contact. This is the “make before break” portion of the switch. These contacts should be used for the motor contactor. If you have more than one high pressure function in a row this will prevent the motor contactor from turning off briefly between selections.
Hope this helps some people out
