Got a look in the equipment room last week and found out that there's space on the pump rack for another two pumps. So thinking that would make it a little better to add a bay to the outside for larger vehicles.
Found the slot drain system while tinkering around and looking to get pros and cons. I think that I'd be able to do a longer run of drain to cover longer vehicles without the whole covered pit concept. Mount a meter system to the outside wall and be able to secure the larger fleet market from the local businesses, and maybe open to expanding to an attendant model with trailer washout. But I digress...
So, slot drain experiences for a selfserve open bay?
www.slotdrainsystems.com
Slot Drain Systems - Innovative Drainage Solutions
Slot Drain provides drainage solutions that are durable, sanitary, easy to clean, load class rated and corrosion resistant.
