Would you mind posting some pics when you have an opportunity. Interested in seeing them!! Thanks!!I made my own years ago using KLeenrite in bay booms attached to my light poles that sit in the middle of each vacuum island. As I recall I was under $150 per vacuum and they have worked great for several years.
I would not do arches on pay vacs. I spent 100K on Gin San arch vacs about 3 years ago and I'm replacing them within next month or two when the new vacs come in. Learned my lesson. Yes it was expensive. Vacs get clogged constantly. Do they look cool YES but if they dont work there good for nothing. NOT BASHING GIN SAN because all arch vacs are same. Also If they are pay vacs customers get pissed when they dont work. If they were free it's no big deal they will move to another stall. Save your self the headache and money.
If your set on arch pay vacs I got 20 gin san arch vacs ill sell you but you cant say I didn't warn you![]()
No concern someone will hit that pole?I purchased the arch from je adams. Built the pole for vacs ourselves.View attachment 11954
I like your honesty I was on the fence about this for 2 years between arch and standard vacs. What brand and how many motors are you going back with just curious. I ended up in the process of standard vacs renovation project now. You did have 2inch hoses on i am sure to reduce clogging.
I disconnect the hose from the vacuum to the arch and run a fish tape through the arch and hose to clear the clogs. Much easier than dragging the ladder out, still a pain to deal with.Thank you. Going back to Jim Coleman two motor combo vacs. The two motor is just as strong as the 3 motor arch vacs. The clean out doors are also completely secure. The locking latches for the clean outs on the gin sans are very poorly designed. You dont even need a tool to pop the latch pin off.
At first I used the tapered 2" to 1 1/2" hose. With that hose the nozzles are 1 1/2" which get clogged way to easily. I remember opening up the new vac area and within 30 minutes I had three or four clogs due to snapple caps, masks, and whatever. I ran that for about a few weeks to a month but after receiving multiple phone calls everyday that the vacs are clogged I switched to two inch hoses and nozzle. It defiantly decreased the clogging but now when it gets clogged its at the connection the hose meets the arch. Pull the ladder out type of fun.
My workers do the unclogging so I dont know exact amount but I would say about 7 vacuums get clogged a week. I see them unclogging at least 1 vac a day. I would say with my Coleman vacs w/ no arch I would get about 1 CLOG A YEAR TOTAL OF ALL VACS.
If the customers picked up all their garbage before vacuuming I probably wouldn't have a problem ever but if we start talking about all the things customers should do we'll be here until next year.
