Arimitsu Pump leaking
Mileski
I have an arimitus pump leaking. Even changed it out to a new out of the box pump and I still have a weap, changed to a new unloader even. Any Ideas?
Thanks.
Sorry, it is leaking/weeping out of the wand. When the water supply is turned off it stops.
It sounds to me like you have a bad solenoid valve somewhere on that bay. It could be the weep valve. The pump will not stop the flow of water.
Undue the inlet hose to the pump and you will probably see it still flowing water. Trace that line back to the solenoid and you should find your problem.
If you have a gravity feed water tank you probably have a bad check valve if it’s a pressure feed you have a solenoid leaking by
Thanks for all of the ideas. After getting some really good advise from Greg over at Arimitsu Pumps, and I ran it back, turns out it was the check valve on the line out of the gravity feed tank. I tried a new that I got locally, however, its cracking pressure was to low, I was able to order one with a 5 psi cracking pressure and all is 'not' leaking. Thanks again.
[/QUOT
[/Q
