I finally spent some time on the machine today and was able to get everything working. It turned out the solenoid coils were all fine. All three of the solenoids were stuck open. I took each one apart and cleaned it using water, a file and a screwdriver. Not the best way, but it was all I had and it worked. Then two of my lines were stopped up, so I hooked them up to the compressor and got them open. Tested all 3 and they function as they should. I appreciate all of the help and suggestions, it really made figuring out the problem much easier as it was the first time I have worked on this type vac.
Thanks.
Thanks.
