Best soap for brush lubricant
Does it really matter what brush lubricsnt you use?
Can you just use JBS Fonic?
Does it need to be low ph?
Anybody who has ran frictions a lot got a good cheap soap that's fine as a lubricant?
High ph, nuetral...?
Thomas, I had not heard that. You'd think this would be very common knowledge. Or @ very least, all those friction installers would stress that.
Id also think low ph would be rougher on brushers...
You're going to call me a condescending prick again, but sometimes that's the only way to answer the questions that you ask here.
The best soap for brush lubricant would be a brush lubricant soap. You don't need low pH or high pH because the brushes are doing the cleaning. You wouldn't brush your teeth with toilet bowl cleaner.
The most lubricating soaps are usually neutral. However, low ph somewhere in the process before the wax/sealants is going to result in a better looking car. But if no attendant prep than you might need a little high to help with bugs, then you benefit from low to help get the high residual off.
Some owners just like to keep it simple, and go all neutral. My istobal is a very thorough washer and if there is a unit on the market that could go all neutral that would be a good candidate. If you are prepping all cars all neutral is not a terrible plan. But then you become overly reliant on labor to make your customers happy.
I inject a low ph additive into my brush rinse water.
Coach, if you wanna try some neutral foamers from quest, try suds up, cherry foamer 3xc, or super suds 3xc, the latter two being hypers.
I am using suds up in a tunnel and it is awesome. Neutral pH, very slick but it does have good cleaning properties. Smells great too as a bonus. I believe you can get it in a hyper concentrate as well.
