I don’t recommend drilling holes in the bottom of the Bezel but if you feel the need and you’re using a Mars validator with a Compact Bezel. This is how to do it. Remove the Bezel from the validator or remove the lower transport from the validator, this way you won’t drill into the bottom board, drill 3 - 3/8” holes in the bottom of the Bezel about a ½” from the leading edge of the Bezel. When you reinstall the Bezel coat the screws with Silicone grease when you install the screws. Let me know if you need a picture
I keep forgetting to get a picture - it will only work with a Mars upstacker. Just take the plastic bezel off and drill a large hole or two in the bottom. I always replace the screws with stainless, #6-32 x 1/2".slash007 said:I'll probably drill holes as well and would appreciate a picture. Thanks.
FWIW have the Coinco Vantage got from Etowah.
Never drilled holes in the unit.
Did drill holes in the box (1/4" bottom rear) to let water out.
Had a few failures initialy . All were warrantied.
Later had a few more. A couple were out of warranty and the repair was about $125.00. Saw the Coinco guys at the show because I was a little PO'd. Some more were now out of warranty and a couple failed shortly after reinstall although it may have appeared longer since I had a couple spares and they might sit on the shelf before needed.
Anyway, the guy at the show told me to send any with isssues direct to Coinco and they would check them out. In the last year or so probaby did this about 4 times.
they warrantied them all. Can't ask for better service than that.
The second one I sent back to the distributor that I purchased it from. At that point, there was a couple of weeks left on the warranty. About 5 weeks later, I get it back with a bill for $95. I called the distributor and he tells me that the validators have to go back to coinco and there is usually a charge for repairs, even under warranty. I was pretty PO'ed and did not pay the charge. The third one just failed and I will be sending it back to Coinco. Good service department but I can't say much for reliability.
FWIW It's now been quite somete since I had any issues with one of my Vantage acceptors. Maybe some kinks were resolved.
