If your pump is getting too much fresh water it will not create enough suction to pull in the
soap from your hydrominder tank. Try cutting down on your water supply temporary, (slightly close a ball valve) and see if that helps. We have had this problem with several National Pride systems. No mater how strong you mix the
soap, if it isn't drawing it in to the pump, it won't show on the car.
