I would never go open loop again. It almost cost me a whole system once. You can get a small reserve tank with a pressure pump that will keep the system filled with the proper ratio.
My ER is in the middle of the bays. I was honestly hoping I could copy your setup biz. If I remember correctly the Takagi has to have a minimum of 40psi to operate. How do
you get 40psi when the pumps are only putting out 14-15 each?
My understanding is that the primary loop is operating at a higher PSI than the secondary loop?
Can someone explain to me the differences between a boiler and a tankless heater? They seem to be very similar but boilers are 3-4x the price? Are boilers plumbed with the same primary secondary loop system or are they plumbed directly into manifold?
Sequoia, what part of the country are you in? Do you have any idea what the utility cost is to operate your boiler? $100 a month? Less than that?
Definitely learning a lot. Thanks to all you guys for sharing your knowledge.
FWIW there are some that require a minimum pressure to heat water without damaging the heat exchanger. I looked into it some time ago when I considered using an on-demand heater with a circulating pump to heat water in an open tank.You don't have to have 40psi to get a demand heater to work. I think they will work with only a few PSI, but you won't get any volume through it.
Got some bad news last night. Pressure tested my lines. A couple of them would not hold pressure at all.
That must be very frustrating after all the work and research you have done. Maybe someone here knows of a way to deal with this??
Based on actual experience with combustion related devices' heat exchangers' ... I would focus more on minimum maintained GPM flow. Not sure if 2Biz is using them with his on demand instant units but we would not even think of running that part of the "at risk" system without reliable flow switches. Low GPM flow during combustion may not take the heat exchanger out immediately but it will most likely shorten its life!
