Buzzie8
My IBA airlift doors manufactured by Ultimate are having problems. It seems as though every bolt I try to loosen ends up breaking off because it is seized up inside the aluminum. I tried presoaking them with PB Blaster penetrating oil without any success. It is getting to be real pain in the butt. A job that should take 20 minutes is now taking an entire day because I need to extract bolts all day long. It happens on the clamps where the rods are clamped to the belt and also on the pistons where the seals need replaced. I have two questions:
1. Is there some way for me to lessen the likely hood of breaking these off?
2. When I put this back together what should I do so it doesn't seize up again?
Thanks,
Buzzie
Thanks,
Buzzie
