Bonus time LED7
tdlconceptsllc
NC
Merry Xmas guys! I was trying to learn more about bonus time from different operators that have & use it. I was trying to help a guy set this up. Do you use the single bonus or double bonus In the programming setup. I want to give bonus time on $5 bills & $10 bills only when inserted into validator. The instructions are not super clear from dixmor on this feature. Any tips would help. Thank you.Thomas.
The bonus time settings in the timer won't do what you want. The timer's bonus settings can either give one single bonus credit when an amount is reached, or can give bonus time for every coin pulse after the bonus amount is reached.
What validators are you using? Hopefully they can be programmed to give more credits for a $5 or $10.
tdlconceptsllc
NC
The validators are MEI Model AE 2612 U3E suppose to take $5, $10 & $20 bills. I just want to give bonus time when a $5 bill is inserted and a $10 bill inserted. Mep your saying I can only choose one & not both right. I was hoping to do both that sucks. Thank you.
No, the bonus only activates when you reach a certain amount of pulses. An example, you're $2.00 to start, 30 seconds per coin, you set single credit, 20 pulses to bonus, 10:00 bonus, it doesn't matter whether you deposit a $5 or five $1 bills or 20 quarters, they get a ten minute bonus chunk of time. If it's set to multiple bonus at 0:10 bonus, once 20 pulses are reached every pulse gets an extra ten seconds, 40 seconds instead of 30. It can also do a pulse multiplier bonus through the aux input, but it will give a bonus for singles too, not just $5 or $10.
Call AECO Sales in Tecumseh OK at 800-682-0358. If the validator can be programmed with non-standard pulses, they'll be able to do it.
I checked my MEI validator computer program and there are no provisions for any custom payouts, just the standard 1 and 4 pulse payouts. I think your best bet would be to call Nick at Dixmor and see if what you want to do can be done.
chaz
Cincinnati, Ohio
I’ve never done bonus time....just warning tone at 60 seconds. Does bonus time actually result in more income. Almost seems confusing to me....plus why penalize the guy with 10 singles
I know a guy who advertises the bonus as "unlimited time" after spending $5. Once 20 credits are reached, the time per pulse is doubled. He claims it brings in lots of customers, but he has to explain it a lot. To deter abuse he added a loop sensor in the floor to cancel the time if the vehicle moves.
tdlconceptsllc
NC
I talked to nick at Dixmor today and he was totally against bonus time. I think I may go another route I didnt know it was going to be this complicated. I see dixmor does not offer random jackpot/bonus time or what I was trying to do with $5 & $10 bills only. It seems like etowah valley and carolina prides proprietary timers are the only ones to do the features I was trying to do which is a bummer bc dixmor repair service and reliability is the best and I thought there timers could do more kind of a let down in reality.
I think it encourages people to put more $ in initially. I will take a phot of my signs that advertise it.
Bonus time is more about rewarding the bigger spenders. On its own, it doesn't result in more income, if anything it directly results in less, but it builds customer loyalty, and the word-of-mouth advertisement will bring you new customers. Also, do you want the customers who deposit the minimum, then dry-brush or hand wash for ten minutes, then deposit the minimum to rinse, or do you want the timer running?
That's just one opinion. I know that rewarding customers is good for your business. I don't offer any sort of bonus, but I routinely walk through the bays and just drop a buck in for people, especially if I'm in the room and hear someone cycling through all the functions trying to get the foam brush on. I'm thinking seriously about selling dollar value tokens from one side of the changer and giving bonus tokens for larger bills. My customers won't understand anything more complicated than that - they won't read anything.
I called AECO and they said the coin pulses can't be changed beyond switching between one and four per dollar. The simplest way I can see to do what you want would be to not accept $1 bills, which I assume is not an option. I played around with my programmable relay software trying to figure out a way to capture the pulses and send them back out with a bonus payout - I haven't worked it out yet, but if the idea might work for you I'll keep trying. The relays are pretty cheap ($130 IIRC), and one could do up to four bays.
tdlconceptsllc
NC
mep you a good dude. Thank you for doing some research trying to help me I really appriciate it.
One of the few times we disagree. I think it encourages a bigger spend. My start time is at $2.50 nd $3.00 (Superbay) and Bonus at $5 My signs say "FREE TIME" XXX MINUTES FREE with $5.00 (different for the $2.50 or $3.00 start) so I think it encourages people to put in the extra $. I have had several customers ask about it.
cantbreak80
Maybe I need new clubs
CO
I programmed a similar idea...BOGO on Sunday mornings
Deposit $2 to start, get $4 worth of wash time.
The PLR program is pretty simple but requires 2 coin pulse wires...to & from the equipment room. Since my PLR was already seeing coin pulses for my boiler/lighting controls, I added it to the program.
For example... between 7:00 & Noon on Sundays (or whatever day(s) and times you desire) the PLR senses coin pulses to start. Once the minimum is deposited, the PLR pulses the timer with the programed number of additional pulses.
Mchas
Why would you want to give bonus time for $5 and $10 bills but not 5x or 10x $1 or coins? That makes no sense.
chaz
Cincinnati, Ohio
agree......the only advantage of handling fewer singles I guess would be a bit less wear and tear on the acceptors and less cash to count?!
PITA to get, sort, or locks you into dollar increment pricing.
Doesn't necessarily lock you into dollar increments. When I switched to dollar coins, my price was $1.50. I converted my dual Hamilton changer to dispense four quarters with any bill.
Payouts went like this:
$1 - 4 quarters
$5 - 4 quarters, 4 dollars
$10 - 4 quarters, 9 dollars
$20 - 4 quarters, 19 dollars
