Booster Pump
OntheBlvd
Help! I'm in need of a 1-1.5 HP 300 psi Booster pump for my water softner system. Can someone tell me were I can buy one reasonable and which brand and model is a dependable pump?
I assume you mean a repressurization pump for your spot-free rinse to your bays. If so, I've always used the 2507-type Procon and 3/4 HP motor, along with a JE Adams high-pressure regulator with 1/4" of the spring cut off. Max pressure is only 250 PSI, but it's very reliable.
