Looking for suggestions and help in regard to clogged nozzles. Installed a brand new pump and of course had a nozzel clog - melted internals of the pump unfortunatly.
So question on Tip size - What luck might you be having with 2506 Nozzle size? Also , do you think it makes sense to cut the pump off if it gets to pressure and overheats - High temp cut off limit if it occurs.. Looking into something like this: https://www.mtmhydroparts.com/products/big-pressure-switch
What have operators come up with to mitigate this - as if and when there is a clogged nozzle - users typical just un it and run it - they really don't care what goes on in the equipment room.. Is there a fail safe to eliminate this potential future hazard?
