nah; that's not enough of a pkg to offer at $16. I was thinking 4 soap passes, hp rinse, lava bath w/l.e.d. light, hotwax, hp rinse 2 then spot free.“Any” in-bay automatic can be made to offer a super expensive wash package.
For example, step one is foam detergent (base, fast break) with color and scent (takes the place of tri-foam).
Step two high-pressure wash.
Step three is hot wax (acidic) or similar super-hydrophobic. Note - hot wax does require lava effect to work.
Step four is setting rinse with spot-free water.
I just seen a new Razor two weeks ago that was a two step cleaning process "lph & hph" it also had triple coat, total body protectant, clear coat it was all in the top package for $12.00 if you wanted to upgrade to a lava arch it was a $3.00 upgrade to any of the 3 wash packages.
How many HP passes?Waxman,
There is a local gas station with a Laser 360 charging $16 for the following:
2 step presoak
Underspray and wheel/rocker spray
Triple Foam Polish
Hot Wax
Spot Free Rinse
Dry- machine mounted
The Hot wax is the only difference from this package and the one below it, which is $11. On the $11 package, they use Double Bond instead of the Hot Wax. I mention this because this wash did not see the need to increase their presoak applications in the bump up to $16, so you might not need to - but I know every location is different.
Time is a factor too - with a machine mounted dry, one or two more presoak passes would make this wash very long, which for $16, I am sure customers want.
