I have a pump that's running perfectly...no out of the ordinary vibrations...holds pressure I'm running at 1200 perfectly, but it's losing oil at an alarming rate. I'm having to add oil every other day. I know it sounds like it should be obvious to see where it's coming from, but I really can't tell. No, it's not the drain...or shaft seals. I seriously can't tell exactly where it's coming from. I know how ridiculous the fact I can't determine where such a large amount of oil is leaking from sounds laughable...and it's okay to laugh at me. I can only say it's coming from the bottom of the pump somewhere...it feels like an even coat of oil when I run my fingers under the pump. Does anyone have any suggestions or ideas? I've never had this problem before.
