CAT 310 wearing out quickly
MDrost1
Grand Haven, MI
Folks,
I have a 310 pump that seems to wear out the valve o rings every month or so. It happens to be o rings above or below the same cylinder every time. Either the top valve or the bottom valve o ring. Is this telling me something? Today the HP was down to about 700psi and the o ring was eaten up pretty bad. Thanks!
BBE
USA
Check out vilco supply. Talk to Joe.
I just got 2 heads back from Vilco. Looks like they did a good job, but haven't put one in service yet to test. I sent them all new seals, o'rings, and valves that they installed for pressure testing.
Actually $149 isn't bad for what they do. All 6 valve seats bored and sleeved with Stainless Steel inserts. They have a video on their website that shows how to put in new seals. You can get an idea of how the whole process is done.
ICEMAN
EAST COAST
send them to kleen rite , they actually press fit the sleeves into the head, permanent fix. I have done 3535, 310 and 5cp with them. Not sure how vilco does it but i thought putting the seals back in had to be done a certain way with vilco
washnvac
Seaford, DE
Agree with iceman. I sent one to vilco, and could never get it right. The KR units are pressed in, and have had no issues with any. And I actually have stopped sending the 5cp2120w in for warranty to cat. I just send it to KR to get fixed right- and done.
I have concerns about Vilco's repair because they use an o-ring under the insert to make the seal, and if that washes out it's not repairable again. DynaJet does a permanent repair with a pressed in sleeve. They may be who Kleen-Rite uses unless they have their own process.
