toddmullens
Can anyone recommend a company that can re-sleeve a Cat 3535 manifold? Ran some low ph acid through it too strong and it’s washed out…
I only had him do Arimitsu heads. He pressed in a permanent seat. I assume that he does the Cats the same way.I.B., have you used that one? Do you know if they press in permanent seats or use an insert that requires an o-ring?
I think it was Vilco.I forget who it was that did the insert with an o-ring. I know a couple guys who used them, and a couple years later the manifolds washed out under the insert and were useless.
You're right, it was Dynajet that did a good, permanent repair before they closed up shop.It was vilco. I sent only one to them. The orings would not stay in place. Never could get it to work right. Have stayed with Kleen-Rite ever since with no issues.
