I've got a Puma pk5030v compressor which has started to trip the breaker when it tries to start up with pressure in the tank. The motor tries to turn the pump, but it can't get it moving and then trips the breaker. When I expel all the air and let it start up with an empty tank, it will kick on and run fine until it turns off at 150psi, but then when it tries to kick back on when the pressure falls to around 100psi, it can't get the pump moving. I'm assuming that there must be pressure built up in the pistons, so most compressors you replace the 'unloader' valve and that's the problem ... however, this compressor uses what they call a 'check' valve that screws into the tank, and there doesn't seem to be any 'unloading' port or hole on that valve. I also don't hear any kind of air released when the compressor kicks off like I do on other compressors. Has anyone dealt with this kind of setup? I have replaced the 'check' valve; however, I used one made by Conrader (https://www.amazon.com/gp/product/B003H7ITEW/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1) that is supposed to be the same as the OEM and the compressor is doing the same thing. I've got the OEM one ordered (https://www.ebay.com/itm/CV1212-PUM...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649) just in case they are different, but they don't seem to be. Oh, and I did replace the start capacitor just in case, but that wasn't the problem either.. anyone have any experience with this?
