Contactor & Overload Relay
rshiggaon
Hello,
I'm looking for a contactor and overload thermal relay compatible with my motor: Baldor CEM3615T General Purpose Motor, 3 Phase, 5 HP, 1750 RPM, 60 Hz. I have attached pics for the contactor and overload relay.
I couldn't find the exact part on KR, and since I'm not entirely familiar with the technical details, I’d appreciate any guidance or recommendations from this forum. If anyone can share a link to the appropriate part on KR, that would be greatly appreciated.
Thank you!
You can take it to any electric supply house or motor shop and they will cross reference to the right ones
Is the overload tripping on the left contactor? Your overload you currently have is a little small for that motor. It should be set for about 16 amps
Yes it did for Bay1, this is the first time it happened. I dont think so it supports 16 amps right?
Correct. You need an overload that 16 amps falls into range. The one you have now is suitable for a 3HP motor which is also a common motor to be used for a SS bay. 5HP motors are often used for "super bays".
Also wouldn't hurt to buy a "clamp around" amp meter and check running amps. I'm a tool snob and prefer expensive fluke but Randy posted about this one working well:
