What type of headaches?Monex fees are running 7% for me and many headache to boot.
The default setup for Pre Auth is the same as your MAX charge for that device. IE if max for a Vac is $5 then the Pre Auth will be $5, ditto if MAX for a bay is $10. I have been told that you can call CryptoPay and ask them to lower your pre auth such that you assume all risk for any charges above the Pre Auth that fail to process due to insufficient funds. The potential issue is that WorldPay is slow to change the Pending Pre Auth charge to the Posted real charge (sometimes up to 72 hours if near a weekend). We receive a few calls per year asking why we charged more than customer expected EVEN with a decal on the meter box that talks about the cc process.Since this started as a Cryptopay thread, I wanted to ask a question. When inside the crypto coordinator and Configure Devices, is the pre-auth $ set by what "purchase type" you select? There's a choice for Wash Bay, Vend, Pet Wash, and Dryer. I'm set to Vac currently (it's a vac) and my testing shows me a pre-auth of $10. Anyone know if the Vend or Dryer has a lower pre-auth?
Thanks!
Maybe CP is using the Max from your bay on all the swipers? I know we have two different credit hold amounts. I have been debating changing the hold amount to the starting amount but frankly the number of calls received is very manageable. Maybe one a month if that.That's curious... I set my max charge to $4.00 which was why I was surprised at the $10 charge on my card. I was going to try a different purchase type and see if that made any difference. Maybe there's a bug with the Max price box on the Vac "purchase type." It is on a vac so I'd be shocked that someone would spend more the $4-$5.
Thanks!
The pre-auth amount is site wide no matter what device the swiper is on. Default is $10 but you can call Cryptopay to change it.
Thank you for the heads up as we add Tap to our swipers!I tried other settings yesterday with the same $10 result. I did get a call back from Cryptopay this morning and got it changed.
On a side note, If you have older firmware on your swiper and add the Tap device, you need to call Cryptopay to pair it. They explained newer swipers will auto pair when adding the tap.
Any useful comments are appreciated. I am purchasing a cryptopay reader and coin box that has yet to be installed. I contacted cryptopay to try and understand exactly what the process entailed as far as getting the customers cards to process. They informed me that they use WorldPay as their processor and that I needed to contact WP to set up the account. What I need help in understanding is this: Is WorldPay the only processor that can be used by the CryptoPay system or are there better credit card processors out there that charge less per transaction? To be fair, I have yet to hear back from WorldPay on what their fees are. Hope this question all makes sense and thanks for your time.
You have touched on a third rail in the SS car wash industry. If you use CryptoPay you can only use WorldPay as your processor. Don’t waste your time with anyone who says otherwise. Just scammers or uninformed as of today. WP is hardwired to CryptoPay for now. WorldPay all in will cost you about 4%. Can vary and you can influence the costs slightly if you have a minimum charge for vacs or bays. Many operators have a $5 min charge (some even more) for CC use in a bay. Customer gets more time but you reduce your costs slightly as there is a per transaction fee plus a percentage. WP has no meaningful customer service and is very hard to reach. They do not care as they have a monopoly on the CryptoPay swiper market. For now their benefits outweigh the alternatives. Don’t get distracted by the alternatives bantered around here. Most are not better or cheaper. Good luck. Once in place it should produce good results for you but the initial process can be painful and unnecessarily longer than it should be. Keep trying them. Once you connect and get the paperwork submitted the process is quick and easy.I have been working with car wash owners for over 10 years now in setting up the necessary merchant accounts for their systems. Unfortunately anytime I hear someone is using CryptoPay, I have to inform them their only choice is WorldPay. WorldPay as acquired by FIS. However, it sounds like FIS is going to spin WorldPay off as it's own company again. Not sure if that will impact anything, but figured it was worth mentioning. If your fees with WorldPay are less than 5% depending on your average ticket size, that is pretty average. If things ever chagne Avoid TSYS direct, Heartland Payments or Global Payments at all cost. Wishing you the best.
