Cryptopay Count Up problem
traveler17
SE NC
Hey I’ve recently finished up putting CP in the bays at one site. Worked fine til this morning. Employee went by this morning and said customer swiped card and and it counted the money up shy one quarter of start time then says “coin “. These are wired to LED 7s. All 4 bays programmed the same when putting info in on the app. No customer service today. count up and count down are wired the same , correct ? ideas would be greatly appreciated. Thank you!!
cantbreak80
Maybe I need new clubs
CO
From Dixmor's Troubleshooting
COIN” INDICATES A CONTINUOUS COIN PULSE COMING TO TIMER FROM COIN ACCEPTER OR A SHORTED COIN SIGNAL WIRE. DISCONNECT COIN SIGNAL WIRE AT TIMER TO VERIFY THIS PROBLEM"
traveler17
SE NC
Thanks I appreciate it!! It’s doing it in 2 of the 4 bays. Big help 👍🏼. Thanks again.
Disconnect the wire from the Cryptopay swiper that goes to the White/Black on the LED-7 timer and see if it goes away.
traveler17
SE NC
Thanks Randy. I’ll try it first thing in the morning. I almost called you but didn’t want to bug ya on a Sunday. :) Thanks for the advice !!!
Count-up and count-down don't wire the same. Which way do you have yours?
traveler17
SE NC
That’s gotta be what it is then. I started out w 2 bays last year doing count down “ don’t ask me why”. I had them installed by a friend when I was out of town. I installed the other 2 bays Friday for count up. I haven’t looked at the manual yet, it’s at the wash. I thought both were wired the same and configuration was changed on the site. Thank you for that !!!
Dan kamsickas
GinSan Technician
Grand Rapids, MI
You can wire them the same. It's in the setup of Cryptopay where the change is made. We do a ton of doors with Cryptopay and they are all wired into the white/black wire.
traveler17
SE NC
So the
So I just had someone else tell me to take on e of the red / green wires and put it in pin 9. Sound right? The two that were not working were originally set for count down
Dan kamsickas
GinSan Technician
Grand Rapids, MI
So the
On the LED6 one of the red/green wires goes to 8 and the other to 9
On the LED7 one of the red green wires goes to 9 the other 6
On the LED8 one of the red/green wires goes to 7 and the other to 9(I think)
On the LED9 one of the red/green wires goes to 8 and the other to 6
Dan kamsickas
GinSan Technician
Grand Rapids, MI
