We are installing Cryptopay on two combo vacs with Dixmor LED9 multi-function timers. Cryptopay says the only way to get it to work somewhat properly is in count down mode. They also say that the button should be made dormant in the swiper setup by indicating $ .00 per button press and the seconds per coin should be set for the most expensive function. It looks like count up won't work unless we are willing to have the same seconds per quarter on every function. The two motor vac price is 45 seconds per quarter and the fragrance is 15 seconds per quarter so that is a pretty big spread. On count up if we set it up so the swiper is active for the least expensive function and the person only uses the most expensive then it is possible they could drive off and someone could push the button and add time with the previous person's card. How do you guys have yours set up?
