Does anybody know if the Cryptopay Tap (only) will work on a Vac, w/out the swipe, & w/out a coin Mech?
Son's are putting these Vacs in richy affluent area, & wants cashless. He thinks people only use a Tap CC.
There are two Cryptopay tap devices. Since you are not using a swiper you want to install the Tap Plus. The other tap device needs a swiper to communicate with the coordinator. I prefer the LED 8 over the led 6 or 7. The mounting studs location for the led 8 is the same as the seven.
