Cryptopay Tap
Does anybody know if the Cryptopay Tap (only) will work on a Vac, w/out the swipe, & w/out a coin Mech?
Son's are putting these Vacs in richy affluent area, & wants cashless. He thinks people only use a Tap CC.
Yes it would. You don't have to have anything else other than a digital timer to accept the signal. I would do count up.
Yup. Works perfectly. Just connect to the timer. That said it may depend on your timer and the timer abilities. We have Dixmor timers.
both would work but for a simple vac a LED6 is fine. The difference is the size so check your plate space. We have all LED7s.
There are two Cryptopay tap devices. Since you are not using a swiper you want to install the Tap Plus. The other tap device needs a swiper to communicate with the coordinator. I prefer the LED 8 over the led 6 or 7. The mounting studs location for the led 8 is the same as the seven.
Can you Swipe & Tap, on the Tap+ ?
