replacing the gantry on my trusty 5000, isn't quite plug and play. Seem to have a prox switch or pulse wheel prox issue. On the first presoak pass the gantry moves forward, stops reverses and goes to bottom of rear and shuts down. Is the range of travel controlled by the pulse wheel counts or is that just confirming movement? I cant find anything to confirm in the manual. If it is just verifying movement, then I likely have a bad rear limit prox sensor. the machine is trying to go through the floor and when it stops on the springs and the PLC stops seeing pulses, it shuts down. After resetting the controller to move the gantry manually, I am not seeing any LEDs for the limit switches on the PLC while still in the "crash" position so a bad limit prox is pretty certain, but is it supposed to be stopping the travel or is the PLC counting pulses?
