I’m going to have to go with Fatboy on this one. It’s a pretty simple control system. If you have 24 volt power coming out of the timer and 24 volts at the mercury relay solenoid and 110 volts at the lower top terminal, but no power on the top terminal your problem is with the relay.
Be sure to order the right voltage mercury relay. I have a
changer customer who had a 24 volt mercury relay go bad. He replaced it with a 110 volt relay and it wouldn’t start, he replaced the timer, still wouldn’t start, he replaced the
coin acceptor and it still wouldn’t start. He called me and told me what the problem was and told me what he’s done. I sent him my spare 24 volt mercury relay and it works. 24 volts isn’t enough power to pull in a 110 volt coil.
