Dan kamsickas
GinSan Technician
Hi, I own a dilling-harris touch 2000 and added a Nayax system to it. Now and again it will fail and shut down power to the Nayax system and start up counting where it left off. It’s happening to all three of my bay’s?? Any ideas?
I would start with the low water cut off. I believe D/H still used a float switch in the rinse tank on the pump stand. Either that switch is out of adjustment(4-6" below the water when tank is full), the switch is bad, the float valve is bad or you have a water supply issue.
