Does coleman have any tech support?
Rfreeman
Ft. Worth
What's your issue a few of us on here have coleman equipment.
I have 4 sites all coleman equipment in the Equip Rooms
geterdone
Ocala, Florida
The error massage prox#2 loose and/or needs to be replaced. Then this morning it said prox #1 and #2 are wired wrong need to swop connection's. I replaced the prox and the cord #2 on Saturday.
That error can be a little more challenging to solve . I don’t know how it knows the difference but the cables have to be on the correct proximity switch. If you don’t have both proximity switches properly spaced between the moving targets you can get multiple error codes . Too close and they don’t get the “off” they need. Too far and they don’t get the “on” long enough . If it’s an older machine you might want to replace both proximity cables. I buy replacement cables from automation direct and they’re only $25 each or so.
