Double float valves
Actually never thought of recirculating the water in the gravity holding tank to the demand heater and keeping the float valve with city water feeding it. Excellant idea! I guess the old Mark VII systems was set up this way with ginormous Jarco Webn boilers attached to them. I should have remembered that! You would want to have an aquastat with the ability to set differential for flexibility to keep the heater from short cycling. I get 6.6 gpm flow with (2) Taco 013's in series to get 40 psi to the heater inlet. You might get another type pump to get you 40+ psi and the rated flow, but this works for me...
