Reds
I have 2 air compressors running 2 IBA's and 2 SS bays. Can I connect them both into my air lines and leave them on and running at the same time? Or should there be a check valve on one of the tanks to stop the other compressor from filling it? Both are set for approx. the same pressure at the moment. But I want them both hooked up and on so that if one fails the other will carry the load. If one is pushing a little more pressure than the other will it flow back into the compressor head of the other one causing resistance? Is there a factory check valve already between the compressor head and the tank? Right now I have them segregated from each other.
