Dultmeier W/Etowah CC Combo??
Whale of a Wash
5 Washes 36Bays 2Vectors
Fargo,ND
I need some new coinboxes, and I like the Dultmeier. The locking system I like better than Etowah. I also like the look better---Has any bought the dultmeier box with the Etowah timer and Credit Card. I seen the combo at the Ica , Do you guys have any experience with the dultmeier boxes-- Good or bad??
I took the etowah valley boxes and added a extra lock bar across front of the locks that etowah valley provides. I had a local metal shop cut and reinforce the slots for the lock bar. The lock bar has to be removed first before any access to the other door locks. I bet Jim could do this for you while he is building them.
lighthousecarwash
Do you really need the new boxes? I just had Jim send me replacement doors for my existing meter boxes. Much cheaper and easier to install than ripping out the entire box and starting over.
Lighthouse.
Whale of a Wash
Fargo,ND
I have A-Oks 25 yr old boxes- so small they can't be retrofitted, and not really even enough room for CC reader. I figured the new boxes would take bills and CC, so might take in a few more $$. They had their boxes at Ica and I liked the way they were designed. I put the links to the two. I am not questioning the security of either, The people at Dult claim almost impossible to get in. I just like the zen of how it is laid out. But have never bought any Dult. equip before
and see what others like or dislike. I am just having new $1 tokens made so my changers will become token machines. The prices are pretty much the same
http://www.dultmeier.com/products/0.48.218.221/2540
http://www.angelfire.com/mech/evmanufacturing/bayboxes.html
Doug P.
I have bought a lot of equipment from Dultmeier going back about 20 years. Good equipment good people. I have also bought quite a bit of equipment from Evalley, once again good equipment and Jim is a good guy. The boxes I have from EValley are the heaviest I have ever used. Nothing takes the place of thicker stainless when they start beating, banging, and prying on them. I have retrofitted 3 washes with Jim's boxes over the past 4 years and if I was ordering new coin boxes tomorrow they would be EV.
Doug P.
I am not questioning the security of either said:
http://www.dultmeier.com/products/0.48.218.221/2540[/url]
If the "T" locks on the faceplate of the Dultmeir are like my pop machine and it looks like they are, they did not provide much resistance from a coople different break in methods.
They look similar to my Coleman Island Vault locks BUT that is the second lock they have to attack after getting thru a thick SS cover over a hocky puck lock.
They are nothing like pop machines. Those are pot metal, use low-security keys and sometimes just use a cam to lock. The car wash ones are forged stainless steel with high-security Medeco locks and a threaded rod into a bolt to hold the door shut. It's not something you can just pry open, and using a dent puller won't do anything but destroy the lock with it still secured.
pitzerwm
Tri-Cities, WA
The reason the pop machines use that cheap lock is that the machine's door is more valuable than the money. They don't want the machine damaged.
