Y yhannat New member Joined Aug 11, 2020 Messages 26 Reaction score 4 Points 3 Apr 13, 2024 #1 What maintenance do you perform on your electric motor? I hear that you need to grease the bearing frequently, if so how do you do it?
M M7T Member Joined Jan 3, 2014 Messages 33 Reaction score 8 Points 8 Location Maryland Apr 13, 2024 #2 Usually I grease them only when is new, only 3 or 4 pumps, then again only is I hear a weird noise or is extremely exposed to moisture.
R Randy Well-known member Joined Sep 5, 2007 Messages 5,883 Reaction score 2,260 Points 113 Apr 13, 2024 #3 You should never pump grease into a motor, the bearing inside the motor are a sealed bearing. All your doing is pushing grease into the inside of the motor.
