washregal
Hello - Have any experienced breaker tripping to the point that you lose HP on a cat pump. All functions work except you lose high pressure. When you go to switch the breaker off then back on - you regain pump pressure - Is there an overheating issue I should be concerned with, or is it merely a breaker change? What experience have you had in regard to this sort of issue?
